-1
Does anyone have a wiring diagram for the Cooper Wiring Devices 390-6105XX-EG1D 3-Way Motion Light Switch?
Asking on SE because this switch does not have standard screw terminals like other switches and instead has three unmarked wires coming out of the back. I lost my instruction manual for it.
    Hello, and welcome to Home Improvement. What colors are the wires? – Daniel Griscom Nov 18 '18 at 21:45
  • Hi @DanielGriscom, one is green and two are black. Thank you! – Vladimir Nov 19 '18 at 5:04
    Green wire to ground. The black wires connect one to the hot wire and one to the load(light) wire. I googled the model number. Just a motion detector and not for 3 way. – user68386 Nov 21 '18 at 21:47
  • @user68386 Thanks for that info! Did you happen to see it mentioned anywher which of the two black wires is which, or it doesn't matter? When I searched for the model number, I was not able to find any documentation, only websites of resellers. Thanks again! – Vladimir Nov 22 '18 at 5:46
    Should not matter which black wire connects to the hot or load. You are most welcome ! – user68386 Nov 22 '18 at 19:32
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
