My water pressure reading from outside water faucet reads 110-120. I reduced on my water pressure regulator and can feel inside the water pressure is decreased but the readings outside remain the same. Possible reasons? Water pressure in the house feels to low now and can’t imagine it’s in the range I get outside on the readings.
  • Where is the pressure regulator located? Is this a well or s municipal water system? – Kris Nov 18 '18 at 1:10
  • Down in basement right next to shut off valve. Municipal – Mike C Nov 18 '18 at 1:21
    Are you certain that the outside faucet is not tied into the waterline before it reaches the regulator? – Kris Nov 18 '18 at 1:26
    Does shutoff valve in basement shut off outside faucets? – Kris Nov 18 '18 at 1:34
    Will need to check that...will advise back tomorrow. Could find my answer quick thanks! – Mike C Nov 18 '18 at 1:34
