I have been reading some posts here and am still unclear. I have an old fixture that I want to install. The fixture does not have a ground wire. Just white and black. My ceiling wires have a ground as well as one white and one black.
Do I simply attach the bare copper to the ceiling box with a screw? I have tested to see if the ground wire is properly grounded by putting my tester on the bare copper and the black.
    Hello, and welcome to Stack Exchange. Does the fixture have a substantial amount of metal that could be grounded? Will it get bonded to the box when you mount it? (A picture could be helpful.) Commented Nov 17, 2018 at 17:14
    Is the fixture likely to be touched by anyone in normal use (once it's mounted)?
    – bib
    Commented Nov 17, 2018 at 17:35
  • The fixture isn't likely to be touched by anyone after it is installed. I intent to screw the ground wire #1 into the screw hole #2 then mount the light.
    – Ken Cheney
    Commented Nov 18, 2018 at 15:35
Many light fixtures are not grounded. If once installed there is no exposed metal even a brand new UL listed fixture may not have a ground. With a metal box the ground wire should be attached to the box by code. Once you connect the fixture to the box it would be grounded if it needed it.
  • Thank you for confirming what I had in my head
    – Ken Cheney
    Commented Nov 18, 2018 at 18:18
