This question already has an answer here:
I just found that the water line behind my fridge had been leaking. The water had found its way under the hardwood floor and ran between the hardwoods and the subfloor a few feet in front of the fridge and began leaking through a seam in the subfloor into the basement.
The finished floor beneath the fridge is warped to hell, which stinks but I can live with it. What I'm concerned with is the floor directly in front of the fridge that I'm hoping won't warp.
The best I could think of to remove the water was to drill a few holes in the basement up through the subfloor and vacuum as much water as I could from the holes. I estimate that that I sucked about a cup of water out from the holes.
Is there anything else I could do to mitigate further damage?
Thanks
marked as duplicate by Daniel Griscom, ThreePhaseEel, Tyson, Machavity, mmathis Nov 26 '18 at 19:48
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • Rent a dehumidifier run it and a fan on low for a couple eeeks – Kris Nov 17 '18 at 18:01
