During an inspection in this house which was built in 1913, we found this outlet that is a 3 prong with an open ground. I pulled it out to replace it with a 2 prong but am not sure what wires go where. I believe the top right wire on the socket is black, so there's black, white and red. I also think there's one other 3 prong socket on that wall that I'm guessing this runs to. I had a handyman with some electrical experience look at it but he wasn't quite sure so hopefully, someone can shed some light on how to do this. Thanks.
2I started to write an answer, but this one may be more complicated. Short answer: Install a GFCI which will provide protection comparable to a ground wire even without an actual ground wire connected. If labelled correctly, that is 100% legal. However, the black/red (== two hots) with only one white/neutral makes me wonder if this is a split (half-switched, half-always-on) pair of receptacles, which complicates things a bit. Is one (or both) receptacle controlled by a switch? – manassehkatz-Moving 2 Codidact Nov 14 '18 at 15:44
2Looks half-switched to me? Replacing with a 2-prong outlet is legal, just be sure to break-away the tab on the hot side if it’s held switched. – Tyson Nov 14 '18 at 15:55
1@manassehkatz that’s entirely possible, and likely the case if OP doesn’t know of a switch. It would be interesting to open up any switch in the room and find out if there is evidence of this. – Tyson Nov 14 '18 at 17:32
1@manassehkatz personally I’d cap the red and stick with black and white. I would not combine them. While a GFCI is one solution that is a small j-box, If OP already has purchased his 2-blade receptacle with no ground, I’d just use that. – Tyson Nov 14 '18 at 17:40
1@manassehkatz use black and cap red. Don't join them, that creates a parallel route, and you should never parallel... unless you are doing feeder so large that no MCM/kcmil sized wire is available to do it in one...and special apparatus on the feed side. – Harper - Reinstate Monica Nov 14 '18 at 17:48
