Please note that I am a diy newbie, and the only electrical experience I have is changing out switches & light fixtures.
I want to install a new ceiling light to a switched receptacle, and I have already put a 2-line+ground electric cable from the ceiling to the switches outlet location
The power source seems to be from the switch (1st & 2nd picture) from a 2-wire cable, and there is a 3-wire cable going from the switch to the switched receptacle.
The outlet also has another 2-wire cable, which I am assuming powers the receptacle that is always hot (4th picture). Or it connects this outlet to the other 3 in the room.
The 3rd picture shows the current state of the outlet area with two 2-wire cables (one from the ceiling light and one always there) and one 3-wire cable from the switch.
I’m not quite sure how to wire the outlet so that one stays switched along with the light (already removed the tab from the hot side of the outlet), and one stays always hot.
I hope I was clear. Any guidance will help immensely. Thanks in advance!
