Trying to install an overhead LED light fixture in a bedroom that previously didn’t have one. Right now the light switch controls a socket into which you can plug a lamp.
Total beginner here.
Inside the overhead light are two white wires, two black wires, and a red wire. I can get the light to turn on, but won’t switch off when I attach the white wire from the fixture to the white wires in the box and the black wire from the fixture to the red and black wires in the box.
The wall switch is set up with two black to the top screw and the red on the bottom. Any ideas? Unfortunately my pictures seem to be too big to attach.
Thanks for any advice!
