So I got a carpenter to fit a stud wall which butts up against a brick wall of the house. (I could've done it but I thought I'd get a pro so it was perfectly plumb and straight.)
It's all plastered with the plumbing and wiring behind, so now I assemble the kitchen units to go into the corner where the stud wall meets the house and I find it's 100 degrees rather than perpendicular!
So if I put the units flush to the walls, there's a triangular gap between them where they join, tapering out away from the wall. Or if I screw them together at 90 degrees, the units will meet the walls in the very corner but at least one of them must come out an inch away from the wall by the time it gets a metre from the corner.
What's the best way to accommodate this? I'm thinking I have no choice but to put the units flush to both walls and then join the worktops over the top at 100 degrees too!
