I'm installing a vapour barrier over the dirt floor in my crawlspace. There is a water heater already installed and I'm wondering if it's a good idea to tape the vapour barrier directly to the bottom of the water tank instead of eptying it, disconnecting it, sliding the plastic sheet underneath and putting everything back together. My only real concern is that the moisture under the vapour barrier will cause the base of the tank to rust.
Thanks.
