I've an aluminium shelf that's 150cm wide, it came with 8 of these 10x50 plastic plugs and 6x60 universal screws.
I've drilled into my masonry wall with a 60mm deep with a masonry bit and installed the shelves. Once there's enough load on them (I'm guessing around 70kg, plus the 20kg for the shelf itself) they couldn't bear the load and started slanting downwards.
Someone suggested drilling with a 8mm bit and using the same 10x50mm plugs to have a tighter fit but I'm really looking forward to hearing other suggestions.
Thanks!
