We just replaced our hot water heater because we were getting a lot of mineral deposits in our fixtures throughout the house because the hot water loop returned to the bottom of the tank and always mixed up the sediment in the tank. Our plumber is trying to install a recirculation pump without using the drain valve (at the bottom of the tank) as the return for the loop. He is trying to explain to me how putting a pump in different places can circulate the hot water through the house and back into the hot water heater. Is this even possible?
Here is the current setup, which isn't really working. Inconsistent water temperatures, and some times little to no hot water.
https://cloud.smartdraw.com/share.aspx/?pubDocShare=A6EDE21171FE47F6804B860EA95206D10BC
Thanks for your help!!
... that is not what the diagram shows – jsotola Oct 27 '18 at 23:48goes around the house
.... this statement makes no sense in the context of circulating hot water to faucets ..... is there something that you are not telling us? – jsotola Oct 29 '18 at 0:57
