I am trying to repair my backpack whose straps wore down. I decided to replace them with bands of heavy duty plastic-like fabric that I found. Unfortunately, it is very hard for me to push a sewing needle through the bands. I can do it if I grip the needle with pliers and apply all my force.
In the end, I used a metal band with some bolt nuts. The solution seems to work, but I am afraid that the sharp edges will cut me open like a trout one day. Also for some reason people collecting money for charity organizations no longer stop me on the street.
My mom has a sewing machine, but she seems reluctant to let me use it. I am also not sure whether it will be strong enough to pierce through the fabric.
Is there some simpler way to connect such sturdy pieces of fabric?
closed as off-topic by Niall C. Oct 24 '18 at 21:25
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Arts, crafts and decorating advice are off-topic as they have little in common with the other home improvement tasks discussed here." – Niall C.
If this question can be reworded to fit the rules in the help center, please edit the question.
  • This site is for Home Improvement; please see the help center for more information. – Niall C. Oct 24 '18 at 21:26
  • Yupps, sorry, I fooled myself by the name "diy.stackexchange" – Martin Drozdik Oct 24 '18 at 21:41
    If you're ok with still using some bolts or whatever, you could try eyelets (like on a tarp) instead of strapping. You'll need eyelet pliers. – Mazura Oct 24 '18 at 22:42
Take it to a shoe repair shop they can sew it together and the tow straps I had repaired cost less than 5$.
