Flipped the light switch for my laundry room, bulb flashed and now I lost partial power in that room and in the garage. No breakers tripped. Cycling them doesn't help. Panel and all switches is 2 years old. There are no GFCIs involved anywhere.
My laundry room is sort of a "bonus room," with a light switch in an adjacent room. When you flip the light switch it turns on the light for the laundry room and the garage. The laundry room has x3 wall outlets, the garage has a couple as well. Power to the wall outlets is not controlled by the light switch.
However, now the laundry room light, garage light and one laundry room outlet no longer have power. Just to repeat, this outlet is not controlled by the light switch. The other outlets in the laundry room still have power, as do the ones in the garage. None of the breakers in the box have tripped. I've cycled every single one anyway, with no effect, still not getting power to the lights or that single outlet.
What happened here? Some sort of a short? Why wouldn't the breaker have tripped? Why would it be affecting an outlet not tied to the switch?
