Thanks in advance for anyone providing insight for me. I apologize if answers for my situation can be found in another post that I've missed.
I have a shed outside my home that currently has no power. I'd like to run power to it and install a 60A subpanel to support a couple of circuits. Currently, I have 200A service coming to the house. The panel inside the home is about 50 feet away so there's a 200A service disconnect with room for 4 breakers at the meter. The shed is about 5 feet from the service entrance.
What I'm planning is to install a 60A breaker in the panel at the service entrance and run 6 AWG copper underground to the subpanel in the shed. I plan to use metal conduit because no one wants to be digging a couple of feet down. I'm comfortable with the requirements for the circuits inside the shed.
Pennsylvania uses the 2014 NFC. Do I have the correct wire for the circuit? Is my approach with the breaker in the service entrance valid? Lastly, do I need a separate grounding rod for the shed? It seems silly to add another grounding rod a couple of feet from an existing one.
Lastly, a (really) crude drawing of it all. Black is existing. Red is proposed.
