I've done a lot of searching and can't seem to make sense of what to do in my situation. I had 2 existing 3 way switches that I've replaced with new 3 way dimmers and also added a third single pole (dimmer) switch to a new light fixture.
Here is what the wiring looked like when I removed the old switches for reference:
Going off of that and making sense of the instructions the best my novice mind can, I was able to wire them up as below:
Wired this way, everything works - however, the new light fixture will only come on if the middle 3 way dimmer is also on. Also the dimming for the far right switch works, but is overridden by the dimmer position on the middle 3 way switch. My goal is to wire them up so I can independently control the new single pole switch on the right and new light.
Is this possible? If so, can someone please point me in the right direction?
Here is an EXTREMELY crude MS Paint drawing:
I will take another look at it when I get home after work.
