I'm looking for a kitchen faucet with a single spray head that can toggle between spray mode and stream mode, but where the setting stays put when turning the water off and turning it back on. I asked the manufacture about this Kraus faucet
faucet in spray mode , but they said that it resets to stream mode after shutting the water off, as I have found most do.
Are there any particular manufacturers that make faucets that stay in spray mode after shutting the water off and turning it back on? Is there a standard industry term to search by for this functionality?
    Hello, and welcome to Home Improvement. Unfortunately, "shopping" questions are off-topic here. That said, we have a Delta pull-down kitchen faucet which retains its stream/spray setting when you turn the water off and then on. – Daniel Griscom Oct 14 '18 at 23:14
We have a Kohler Model K-10433 that has a pushbutton near the spray head. Pushing it one way gives a stream and pushing it the other way gives a spray. It will remain in whatever position it was in when the water is turned off. However this unit was installed back in 2009 so I don't know what Kohler may have available now.
|improve this answer|||||
Got this (https://riobelpro.ca/en/product/card/NJ201) installed in 2017. Quebec, Canada.
Good old button, so stays how you want.
