I have a dilemma. In my kitchen, there has always been an unused electrical box in the ceiling. On the wall in my kitchen, there has always been a switch that doesn't control anything. I always assumed that the switch controlled the ceiling box. (I know what happens when you assume, but hey...)
So I built a fixture that holds 5 pendant lights (led). I wired the fixture to the ceiling box yesterday and the lights worked perfectly. However, the switch doesn't control the lights.
I figured out that the ceiling box wire connects to a wall box that has two standard side-by-side plugs, and three lines coming into it. (See drawing)
My question is, what should I do? Can I replace one of the plugs with a switch? Is there a remote control that I could hook up to the wiring in the fixture itself?
Thank you so much.
Chris
