Is there another way to crimp aluminum sleeves without having to buy a $40+ crimping tool that I will only use for this one project?
Or at least is there a crimping tool that has another use?
I don't want to spend so much on a tool that will only be used once and will then be stored in a box until I die.
    Why not buy one on eBay, use it, sell it on eBay. Or use a regular tool rental shop? Oct 11, 2018 at 12:50
  • I'd go with the tool rental. Things like that can be incredibly cheap to rent for one day, especially if the sales price is only $40 to begin with.
    Oct 11, 2018 at 13:54
  • Find a factory which does this sort of work. 'Google 'lifting' as a start. There's one in most towns. Take your stuff there, they will do a pro job for a bit of cash.
    – Tim
    Jul 14, 2021 at 9:00
7 Answers 7
THIS METHOD SHOULD NEVER BE USED ON WIRE ROPE INTENDED FOR LIFTING PURPOSES. THE RESULT SHOULD BE ADEQUATELY TESTED WITH AN INTENDED LOAD UNDER CONTROLLED CONDITIONS WHILE HORIZONTAL BEFORE USING IT IN THE FIELD. (If the intended load is a very light one, such as for a dog tie-out, using your own body weight is one way to test it.)
For up to 3/16" BARED wire rope (that's the metal dia, not including any covering) I hammer in 3 dents. Using a nail about 3/16" dia. (for a 3/16" ID ferrule) laid across a DOUBLE ferrule, put 2 dents on one side, no closer than within 25% of the END of the ferrule flip it over and put the 3rd dent on the opposite side, spaced between the first 2. Don't go hammer crazy. With a properly sized ferrule, the dents don't have to be even the WALL thickness of the ferrule itself for max holding power. I use a traditional anvil's surface, but if you have a vice with an anvil surface behind the jaws, or a piece of railroad rail, or any THICK piece of scrap steel, lay the cable and ferrule on that. DO NOT DO THIS ON BARE CONCRETE-its an eye hazard and you can easily damage the concrete surface. Plus the ferrule doesn't look as good when you're finished.
Assuming you were thinking of using these ferrules to terminate wire rope, and you're only making a few connections and not hundreds, my advice is don't use them at all: use Wire Rope Clips instead.
Wire Rope Clip
They're not quite as cheap or quick to assemble, but if you're only doing a few, there's not much difference, and the only tool you need is a wrench.
Note that unlike the ferrules, they do have to be installed a particular direction.
Don't saddle a dead horse
Just crush the thing with any tool you have around.
I googled the phrase "crimping aluminum sleeve without tool" to find examples of a child using pliers to get this done: https://www.youtube.com/watch?v=rMJETUcYNxg
If you can use a big vise to crush them down, that's probably the most 'controlled' way. Otherwise, use pliers, or get a hammer and chisel and dent the sleeve at two or three points with the chisel.
Plan on destroying one or two sleeves first just to get the technique down. Then, once you have one that looks right, really try to rip the wires out (to verify that you have a good internal connection).
  • Self-locking pliers (mole grips) work very nicely for this as you can set the closure to be repeatable
    – Chris H
    Jul 14, 2021 at 10:29
I often use a thick nail set and drive two divots on each side of the ferrule on concrete, staggered from each other on opposing sides.
Simply crushing ferrules with a vice or Vice-Grip doesn't leave me with much confidence in the holding power of the crimp and tends to leave a less pretty result. Creating a zigzag path for the wire rope is more reliable.
I just went through this! The guy at Home Depot practically rolled his eyes when I asked him where to find a “swaging tool”. Turns out, just bashing the crap out of them with a hammer (on our concrete garage floor) did the trick for the FOUR cable ends/ferrules I was dealing with. Who knew! Upside: very satisfying to bash things. :D. Caveat: I’m a chicken-armed chick, so bashing for me is probably gentle compared to a dude with actual muscles. Start “gentle” and work up. I was dealing with 3/32” cables. Project is finished!
    You are far better off getting the proper, ratchet-type crimping tool for whatever ferrule/cable-end/... you're using, especially if you have chicken-arms (or noodle-arms for that matter). -- Another noodle-armed geek May 10, 2020 at 2:17
    There’s something very satisfying about having the right tool for the job, especially if you have tried to do it with Incorrect tools.
    – Alaska Man
    May 10, 2020 at 4:56
For more confidence leave extra length at the end and use a second ferrule. For extra extra, leave extra length at the end and fold back to meet the loop then ferrule the end onto the original loop. Will look unusual but should be very stong. Note absolutely none of these tricks should be used with wire railings or where other dangers are apparent.
For smaller diameter cable (3/16 and under) use the bolt cutter part of the jaws of a pair of 8 inch Vice Grip pliers. In case you never noticed it that’s a little anvil and chisel built into the area of the jaws that are closest to the joint. By adjusting the thumb screw you can set the crimp depth very precisely. Just take care not to cut through the ferrule. If you don’t already own one the name brand costs about the same as the crimper and the knock-offs can be found for under $20. Plus it is a tool you will use often enough to justify the purchase.
