It’s driving me insane. A licensed electrician installed about 12 recessed lights and a couple of them keep flickering.
I have tried:
1) Changing the LED inserts 2) Changing the switch to a flip switch instead of a dimmer 3) Jiggling the recessed cans
I’m worried that this means that there are loose wires in my ceiling that will cause a fire. What do you guys think???
  • What kind of light bulbs are they? You mention LED, are the LED bulbs ran directly from house voltage (~120V, or 220V), or is there a voltage converter and they use 12V DC or something else? Do the same bulbs flicker in another building / identical socket? How fast is the flickering, and how often? And do regular incandescent bulbs flicker at the same time & rate? Is there another appliance going at the same times, like a washing machine? If you've already changed the LED lights themselves and the switch that leaves just the wires (which should be "on" or "off"), and the electricity. – Xen2050 Oct 5 '18 at 23:18
  • You should ask the licensed electrician for assistance. I’d sure hook those lights up somewhere else and see what happens tho. – Tyson Oct 5 '18 at 23:57
  • @Xen2050 - it’s one of those led trim combo kits – Jeff George Oct 6 '18 at 1:59
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
