I pulled up about 8 roof tiles from the valley to the middle of the roof to work on the batten underneath. However, when I went to replace the tiles, which I did by replacing the last one I removed first, I could not get it to set properly in the groove - it sticks up slightly where it should interlock with the adjacent tile, especially towards the bottom. It is not a lot, maybe 1/4" but it is noticeable and I think it's going to allow water under the tile if it rains much. I tried playing with the tile moving this way and that and couldn't figure out how to make it lay completely flat. I was able to replace the remaining tiles, and while the second tile sticks up slightly too it is less (maybe half what the first one sticks up by) and by the third tile they all lay flat properly.
The second tile is obviously sticking up because the first tile is in the way, but I can't see anything in the way of the first tile. How can I reset the first tile so that it lays flat?
Update: Here are a couple pictures, I noticed after taking the picture that the tile diagonally above and away from the first tile I put back is also sticking up a bit. front view side view
  • Picture would help. How are these tiles held in place? Are they mortared? If so then you may need to replace the mortar to have a good fit. Commented Oct 3, 2018 at 13:58
  • I agree a photo would be helpful here, are the tiles in the same positions now as they were originally I know I have had trouble when removing tiles to repair valley flashing if I had some out of order don't know if over the years they warped (I wouldn't think so) but this was my best guess.
    Commented Oct 3, 2018 at 14:56
  • @ShimonRura Pictures added
    – Michael
    Commented Oct 4, 2018 at 2:37
  • @EdBeal Pictures added
    – Michael
