We just got a Toro electric-start "Recycler"-brand lawnmower. The instructions for charging/starting it reference a strange plastic piece that I don't understand.
Here's the piece of plastic:
enter image description here enter image description here enter image description here
Here are the instructions from the "quick start" guide:
And here are the instructions on the mower itself:
Based on the quick-start instructions, it seems I need to have the plastic piece in one orientation when charging, then to run it I need to take it out, rotate it, and replace it? But it's not clear which orientation is which.
And based on the instructions on the mower, I'm supposed to push it in to start the mower... except it doesn't push in any further than its base-position, so that can't be right.
I'm so confused right now. How do I use this thing?
  • Is there some packing in the button hole preventing the button from moving down when pressed? Have you charged the mower for 24 hours? Sep 30, 2018 at 23:36
    Did you pull the running handle switch to the fixed handle before you pushed the start button? Sep 30, 2018 at 23:44
  • it is a start key .... see last picture .... 1. insert key, 2. pull lever, 3. press key
    – jsotola
    Oct 1, 2018 at 5:58
  • the quick start page .... step #7 ... choose between electric start (top of page) or manual start (bottom of page)
    – jsotola
    Oct 1, 2018 at 6:01
The instructions direct the button to be put in only one way. The curved arrow does not mean to flip the button over; it means the button causes the engine to turn.
When you stop the mower it directs removal of the button and taking it away (so some unauthorized user can't start the mower just by pulling the bail and pressing the button).
    This turned out to be correct. After putting the button in, you have to push really hard to get it to snap in. After that, it functions as a normal button. Oct 19, 2018 at 18:28
