I dropped one of the toilet bolts in the drain hole. It's in the basement and set in concrete. I tried to vacuum it out but couldn't.
How serious is this, will it get flushed down or do I need to trace it it a snake camera and pull it out somehow? The pipe turns horizontal right after the elbow in the ground and it's a 4" pipe.
Or can I just leave it?
I thought toilet bolts are pretty standard
... how are we supposed to know that kind of a bolt you used? ..... anyway, a 3" bolt should be too short to wedge inside a 4" pipe, so i would not worry about it ..... solid waste should push it into the main sewer line fairly quickly
