I moved to a flat that has on the ceiling 5cm holes with no way to screw or a hook to hang up a lamp, just the cables coming out, like the pictures attached.
What type of support could I use to install a basic e27 socket without the need to drill or damage the ceiling?
build-in lamps could be an option but how to fix them?
