A wooden plank on my fence is sagging. It's stuck so it's very hard to push it back up. How do I put it back in place and what tool should I use?
I would use a tool called a "superbar" (sometimes called a pry bar). It looks like a crowbar, but is smaller and flatter
Place some wood on the pry part and use it to help push the board back into place.
  • Might be worth adding to add some construction adhesive between the two boards prior to prying it back into place, then toe-screwing it together (even if temporary until the adhesive dries). – stevieb Sep 21 '18 at 18:37
    Or wonder bar, I would use a 2x4 and fulcrum , after it is in place it will need toe nailing or it will slip again. – Ed Beal Sep 21 '18 at 18:39
