I have a Carrier Infinity system with model # SYSTXCCUID01-V thermostat/control. I need to temporarily remove it from the wall.
I found a diagram of how to install it:
(diagram source)
I do not know how to release the interlocking tabs. It feels very tight and I don't want to break it.
It really will just pull straight off. (Just did it!) No tools required. It feels tight but it seems designed to mount on/off this way.
(Encouraged to try that by this post).
My advice is to gently pull straight out. I did it but I was not sure due to the difficulty of the release. Secondly, I would not ever buy an AC system that would only work with a special Thermostat! A replacement for my Infinity by Carrier is $960.00 (not customer friendly). The only reason my Thermostat is a problem is that the AC button broke. Otherwise if I remove the face and manually switch between Air and Heat- I can get by.
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably take our tour so you'll know how best to contribute here. Dec 30 '19 at 18:48
I had the same problem. I tried to pry the thermostat from the back panel with screwdrivers with no luck. I was concerned that the plastic parts would break. Finally I tried a method that worked well. I used my finger tips on top of the thermostat to push opposite directions on the thermostat and the back mounting plate. It came apart quickly.
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably take our tour so you'll know the details of contributing here. Apr 9 '20 at 11:49
Careful, these 2 pieces will come apart, but in my case, the drywall anchors gave up first. Then a medium screwdriver was needed, but it wasn't tough. More mad about the drywall anchors.
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably take our tour so you'll know how best to contribute here. Nov 4 '19 at 3:31
Yep first generation split /pull apart at the center seam.
    Hello, and welcome to Home Improvement. If you'll take a couple of minutes to take the tour and read the help center, you'll note that this is a Question & Answer board, not your run-of-the-internet discussion forum. Nov 24 '20 at 22:47
