There's a small (SMALL!) walkway next to this staircase that was originally covered with carpet. It's been ripped out and replaced with laminate, but now there's a crevice between the laminate and the wall molding. Any suggestions on how to fix or cover up?
pic1
  • slide the laminate so that it touches the molding – jsotola Sep 30 '18 at 2:44
Small gaps like that are often filled with white painters caulk. Be sure that it is paintable. Get the small tube (not the caulk gun size). Cut the nozzle size to small.
It can be squeezed into the gap and carefully wiped off the laminate with a damp paper towel.
