I have a situation where most of the electrical outlets are placed low--about 2 inches above the floor measured from the bottom of the outlet plate. It originally had base moldings which rose to about a third of the way up the outlet plates, but was cut badly to fit and globs of caulk was used to fill the gaps, etc.
I am going to install laminate flooring and was wondering if the matching quarter round mouldings can be used to the walls without the base moldings (after finishing up the rough spots in the drywall left behind). Floor guy said it would look strange, but I've seen it looking good in a 1940s home. Is there any issues with this install?
  • How will you keep the bottom 6" of your walls from getting kicked up? Sep 18, 2018 at 16:41
  • Yes .most of the outlets would be behind furnishings but the exposed ones are an issue.
    – Gary Young
    Sep 18, 2018 at 16:59
  • Forget the outlets, What about your walls? House rule, don't scuff the walls with your feet? Wrap the vacuum cleaner with bubble wrap? Baseboards are for reasons... You don't want to build a perfect flawless show house that no one can actually live in... Sep 18, 2018 at 17:12
It's possible to do, but not easy. There isn't much surface area on quarter rounds. Usually there is a significant gap between the floor and the wall to allow for expansion. Usually, the quarter round is nailed to the baseboard, which is nailed to the studs. Without baseboards, the gap between the flooring and the wallboard doesn't leave much material to attach the quarter round to.
Just because the previous baseboards looked bad doesn't mean your new ones have to. Since it sounds like you're pulling the old ones out, you have the opportunity to select ones that will make installation around the outlets easier or prettier.
Alternatively, if all of your electrical wiring in the area comes down from the ceiling, it might be a simple matter to install new electrical boxes at an appropriate height and move the outlets up.
  • Thx..would a liw baseboard of about 1.75In be suffice to take care of expansion or shifting issues? Just looking for the simplest approach
    – Gary Young
    Sep 18, 2018 at 16:52
    A low baseboard would work. If that will cover the horizontal gap isn't something I can see. If it doesn't, then you add quarter round.
    – longneck
    Sep 18, 2018 at 17:17
I agree with longneck about the wall finish behind the shoe molding likely being uneven and gapped from the floor. I think I'd install period-appropriate base molding with a squared top profile and extend behind the boxes with additional woodwork. It wouldn't be difficult to fit around the outlet boxes. You'd need to install box extensions.
            ___________________________
            |    __________________    |
            |   |                  |   |<-- base trim extension block
            |   |      outlet      |   |
 ___________|___|                  |___|___________________
                |      plate       |
                |                  |        base trim
You could also get fancy and actually fit the baseboard around the outlet.
