I am having a window closed in, on a cinderblock wall. My contractor laid mortar horizontally when he put up the wall. But he left gaps on all the vertical sides of the cinderblocks. When I questioned him about it he said it was excepible to fill those gaps after all the bricks were laid. His guys tried the rest of the day to force mortar into the gaps. I can now stick a small rod into lots of holes they left. I also noticed when I put a straight edge to the side of the wall the bricks are not aligned. Some are pushed back as they stagger upwards. I called him the next day to ask questions. He called my husband and I crazy and told us that “they are not done”. Should I continue to let him keep adding mortar? I can not tell if there is anything between some of the bricks. There is however lots all over the fronts of the bricks. Will that hold them up over time? I am not sure how to move forward.
    Can you add some images of the holes and the window? It would help us to advise you. – Machavity Sep 18 '18 at 1:47
You have several issues: 1) proper mortar installation, 2) mortar on face of bricks, 3) contractor’s license.
1) Laying bricks is not just sticking mortar between the bricks. Bricks are embedded into mortar. The bricks should be clean and wetted prior to COVERING the bricks...it’s not acceptable to jam a little mortar between the bricks because it will not bond, will not be watertight and will be susceptible to spalling due to frost, moisture, etc.
2) Mortar must be removed immediately from brick faces or it will stain the face. The only way mortar, that has aged on the face, can be removed is with acid. Using acid will remove the finish and cause the brick to leak (water penetrate into the brick). Then, a strong wind will drive rain into the bricks causing damage from moisture, mold, etc. Also, frost will crack the bricks.
3) I would check with your local Builders Board and see if they are licensed contractors. I doubt it. You can see if they have claims against them and you can file a claim against them. The builders board will investigate and make a determination. I’d call your local Building Code Office.
| improve this answer | |
  • I agree, it's crazy to think you could build a proper wall section that way. – Ed Beal Jan 30 '19 at 23:19
