I am about to install the ecobee 3 lite thermostat. On the thermostat end, there is no C wire - just the typical 4 wires - R,Y,W,... On the furnace end though, there is white C wire too, which I do not know where it leads to (definitely not coming to thermostat).
Given the situation, following are questions I am looking answers for: 1. Can I simply remove the existing C wire and replace with the C wire from the PEK kit from ecobee? Wondering what else may break in the house. 2. Can I simply keep the existing C wire as is, and add the C wire from the PEK kit in addition, at the same terminal?
Any info or any tips that can help me out in this situation are highly welcome.
enter image description here enter image description here enter image description here More pics:- enter image description here enter image description here
    Can you post photos of both ends of the thermostat wiring, and the wiring diagram (or at least a make/model) for your furnace? – ThreePhaseEel Sep 17 '18 at 3:51
  • We need either photos of the wiring, or you'll have to include the make and model of the furnace. Also, do you have air conditioning through the furnace? – Tester101 Sep 17 '18 at 11:42
  • Hi Folks, I added a few pictures. Hopefully this helps? – Aditya Sep 17 '18 at 18:37
  • It looks like you have air conditioning connected to your furnace(y terminal has 1 wires). The c terminal is providing power to the air conditioner control circuit and turns on the air conditioner when the y terminal is connected by the thermostat. You need to run a wire from the c terminal of the furnace to the c terminal of the thermostat. That will provide 24 vac to the thermostat. – user68386 Sep 17 '18 at 19:33
  • Thanks user68386. To run the c wire from the furnace c terminal to the thermostat, the PEK kit can help, right? That said, as you can see, there is already a white wire on the furnace c terminal. Should I simply remove that and add the one from the PEK kit, or keep the one in the picture and add the PEK kit one too, to the same terminal? – Aditya Sep 17 '18 at 20:55
You can connect two wires to this terminal
You can indeed connect the C wire from the PEK to this terminal in addition to the air conditioner's C wire. If you look closely at your Y terminal, in fact, you will see it is already double-tapped with the Y wire from your thermostat and the Y wire to your air conditioner.
