My front door lever/latch feels as if locked from the outside when unlocked, either you have pull the door a bit and then press the lever or press down really hard and the lever opens the latch. Is this normal, or is there a way to fix this?
This is likely related to alignment of the latch (the mechanism that runs through the edge of the door, from the lockset to the door frame) with the strike plate (the metal plate attached to the door frame which guides the latch plunger to its "latched" position).
Look closely at the strike plate for signs of misalignment; like heavy off-center scratches in the area where the latch "strikes" the plate. Look for indications that the latch is not lining up with the hole in the strike plate. Sometimes this happens due to settling/movement of the house due to seasonal changes, and can be remedied by filing the hole in the strike plate. Try removing the strike plate and watching how the latch behaves, at the edge of the door, when closing the door.
There could also be one or more of numerous other problems: loose hinges, loose lockset screws, warped jamb, warped door, worn out latch, worn out lockset, wall movement, etc. Start troubleshooting and eliminating possible causes until you find what the problem is.
    I looked at the strike plate and it had a clear scratch and was pretty bent. I removed it and straightened it out and that fixed it, thanks! – mac_33 Sep 15 '18 at 18:49
