I currently have a 3 family where I am looking to install compact washing machine and a dishwasher for all 3 floors. It is an older building. Will be going with permits.
The first floor main panel is 40 amps with aluminium wire gauge 6 going to a sub panel. The subpanel has some room. It look like on the subpanel total amps is 290 when i add it all up.
Would I be able to upgrade the main panel from 40 to 50 amps and would it be able to handle an additonal washer and dishwasher. Currently the apartment has fridge, 2 AC, and lighing with two ceiling fans.
2nd and 3rd floor have a 50 amps main panel with alumin wire again the wire is 6 guage. Has additional spaces on subpanel. Has 1 fridge, 4 AC and 3 Ceiling fans and room lights.
I have attached pics of the first floor and second floor breaker.
Thanks for your help.
Pooja.1st Floor Panel Info1st Floor Panel 2nd Floor Panel Info2nd Floor Panel2nd Floor Sub Panel
15
  • Where are the "house loads" of this building currently fed from? (things like exterior lights and whatnot) Can you supply photos of the building's metering/main breaker setup, for that matter? – ThreePhaseEel Sep 14 '18 at 17:21
  • Sure I am currently away til Monday to take the photos. The exterior lights are you referring to common lights if so that a separate box and is controlled by a separate main panel downstairs. Each apartment and the common building election have it own main box. – pooja Sep 14 '18 at 21:38
  • The wire coming in from the meter is gauge 8 – pooja Sep 14 '18 at 21:42
  • Can you post photos of the main box for the common building lights/etc? – ThreePhaseEel Sep 14 '18 at 21:54
    drive.google.com/… – pooja Sep 17 '18 at 19:05
