I thought this would be simple but of course I'm in over my head. We have a two button (paddle style) light switch in the bathroom. The top turns on a ceiling light and the bottom turns on a heat lamp and exhaust fan (both run together).
The back of the existing switch has 2 black wires plugged into bottom holes on back and 1 red wire plugged in top hole on back.
I went to Lowe's and bought a 2 in 1 paddle switch but I'm confused on where the wires should go.
Left side has 3 screws (gold,black,gold) and right has 1 black screw. There is also a fuse that can be pulled out on the back?
How this should be wired? Do I even have the correct type of switch?
ETA: The switch is a Legrand RCD11WCC6.
