I am replacing a ceiling fan+light unit. It is controlled by a on/off switch for the fan and a dimmer switch for the light unit. From the ceiling I have a bare wire, black, white, red wires. The fan has a white, black, blue, and green wires.
  • How was the old fan/light connected? Sep 13, 2018 at 18:06
I,ll describe the process of elimination that ThreePhaseEel describes.
First, you connect earth to earth, because it's a world standard that green, green/yellow, or bare is always earth. So that's easy.
If neutral is present, it must be white. Neutral must by nature be present on both sides here, so the whites must be neutral. Connect them, done.
That leaves two colors from the wall and two from the fan. Colored wires must be hot. There are only 2 ways to hook them up. We're not sure, but it won't be destructive to try one way and see.
For your average fan+light combo:
Wire bare to green + the box grounding pigtail (should be green or bare as well), white to white, black to black, and red to blue.
If the dimmer controls the fan at that point:
If you find the dimmer switch controlling the fan at that point, undo the black and blue wires from the fan in the ceiling box and wire them black to blue and red to black.
    Assuming that the red wire will be the switched hot to the light is reasonable, but to confirm it before connection, you could remove the switch plate and see if the red wire is attached to the switch for the light. Sep 13, 2018 at 18:05
