I hired a guy to refinish hardwood floors. I am not happy with his work so far because he didn't sand into the wood at all. He basically just sanded off the old floor finish and then started applying polyurethane on top. The sanded floor doesn't look that different from before the project started, except now it's a little shinier because of the new polyurethane.
When I asked him why he didn't sand deeper, he claimed that because the flooring is pine (it looks like oak to me, but he says pine -- whatever), sanding into it would create blotches and discoloration. Is that true at all? It's also an old floor (about 100 years), if that matters, but it is in good shape overall -- very few nail heads are showing, and the boards are at least a half-inch thick (I pulled one up to check).
I was under the impression that when you refinish a floor of any type of wood, unless it is really thin, you sand it down to the bare wood. I realize you might not be able to sand deep enough to get out every stain or dent, but I thought that you at least have raw wood before you apply new finish.
Is this guy taking me for a ride, or is it true that you can't sand into pine without having problems?
