I have a 50amp gillette generator 9000 watts. My question is if i put a adapter to go from NEMA 14-50P to L14-30R with a nema 30r back feeding through my dryer plug would that be safe running a 50 amp generator.
Yes i know back feedings laws and everything just hypothetically asking if using a 50 amp generator through a 30 amp wire and circuit
    An unsafe thing doesn't become safe just because you want to do it. Sep 10, 2018 at 17:59
  • What's the output voltage of this generator? Single phase or dual phase? At the very least, you'll need to put a 30 amp circuit breaker between the generator and the dryer plug, but even then I wouldn't consider it safe.
    – mrog
    Sep 10, 2018 at 18:01
  • Its 9000 watt starting 8000 watt continuous. Single phase. Theres a breaker on the generator im sure. Im just wondering is the amps are safe. Sep 10, 2018 at 18:18
  • Max Power Rating: 9000 Watts Continuous Power Rating: 8000 Watts Voltage: 120/240 Single-Phase Frequency: 60 Hertz Sound Level: 79 dB(A) at 7 Meters Rated Amps: 66 Amps @ 120 Volts (Single Phase) 33 Amps @ 240 Volts (Single Phase) Fuel Type: Gasoline Auto Voltage Regulation: None Portability Kit: Optional Tank Size: 8 Gallons Run Time (75% Load): 9 Hrs Battery: None Outlets: (4) NEMA 5-15R 120V GFCI (1) NEMA L5-30R 30Amp (1) NEMA L14-50R Alternator: Brushless Sep 10, 2018 at 18:18
    Hypothetically, yes you could wire it up to make it work, but don't try it. You'll be risking the lives of utility company workers if you don't do things exactly right every time you use it, or if you have a faulty circuit breaker. You'll also risk a house fire if you aren't extremely careful about limiting your power use to what the dryer circuit can handle. It's better to go without power than face those risks.
    – mrog
    Sep 10, 2018 at 18:54
To answer your question , yes it is unsafe. This design is dependent on a human to ensure the main breaker is in the off position when powering the panel from the generator. Humans make mistakes. Mistakes like this can kill.
