I want to wire a 60A subpanel that is 220' from the main source. The wire will be AL and run through a buried conduit.... Must meet Ontario Electrical code
  • Hello, and welcome to Stack Exchange. Unfortunately, questions on local code are off-topic here. – Daniel Griscom Sep 5 '18 at 21:31
    I'm voting to close this question as off-topic because it asks about local code. – Daniel Griscom Sep 5 '18 at 21:32
    How much amp loading do you actually expect to see on a regular basis? Daily peaks, not extraordinary peaks? – Harper - Reinstate Monica Sep 5 '18 at 22:41
  • I have 2 RV's that are plugged in to 30A receptacles…. Not expecting both to run AC at the same time but one could add a base load to any other equipment operating in the shop – Bob Sep 6 '18 at 12:58
