I’m changing light switches to decora from toggle.
I have 4 switches to one light fixture where 4 of the 3 switches have 5 wires and the 4th switch has 3.
  • 1: 2 red 2 black 1 ground
  • 2: 2 red 2 black 1 ground
  • 3: 2 red 2 white 1 ground
  • 4: 1 red 2 black 1 ground
If a 5 way requires 2 4 way switches and 2 3 way switches - which gets 4 way switch? What do I do with the extra wire on the switch were I put a 3 way decora?
  • 4
    Welcome to StackExchange. This information could have several meanings, especially in the 1st and 4th switch. What we need is photos of the wiring. Wire color is essentially meaningless in 3/4 way wiring, but pay very close attention to screw color. – Harper - Reinstate Monica Sep 5 '18 at 3:58
    Can you post photos of the insides of the switch boxes? – ThreePhaseEel Sep 5 '18 at 4:01
  • I'm a little confused by your descriptions: I have 4 switches to one light fixture where 4 of the 3 switches Do you mean 3 of the 4 switches? And then you go on: If a 5 way requires 2 4 way switches and 2 3 way switches A five-way system requires five switches - you list only four. – mike65535 Sep 5 '18 at 13:43
  • There is still a switch to find, unless it was previously removed from the circuit. In standard multiway switched, each “end” will be a 3-way, and all the switches in between will be 4-way. If you have an extra wire where you want to put the Decora switch, then you bought the wrong switch, you need a Decora 4-way, not 3-way. – Tyson Sep 5 '18 at 14:32
  • @Tyson we can't say that, because we don't know what the 2 blacks are doing in switch 1. It's entirely possible both blacks go to the same 3-way common, and one is simply carrying power onward to another switch or load. – Harper - Reinstate Monica Sep 5 '18 at 15:55
