I recently installed a Lutron Caseta (PD-6ans) switch that connects to a half-hot outlet. I noticed there is still a trickle of electricity coming out of the switch even when it's off. Enough to make a non-dimmable LED bulb flash in the lamp plugged into it. I switched to a dimmable LED bulb and that fixed the flash problem, but there's still a trickle going to the half hot side of the outlet when the switch is off. Is that a big no-no? How can I fix it? Or am I worrying about nothing?
Thanks for the help!!
Edit: Here's the entire wiring of everything in question. There were two three-way mechanical switches that controlled two half hot outlets (used for lamps). I replaced one of the mechanical switches with a PD 6ans and wired the other mechanical switch according to how Lutron says to do it. Everything works how I want it to, but still have some current flowing when it should be off.
