-1
We had a sock with those little rubber/sticky grips sitting on this dresser for a while now. This evening after a doing a whole house cleaning I happened to notice a small spot on the dresser and after picking up the sock saw these small "potholes" where it was sitting.
How could I go about spot fixing these pot marks? I'm not looking for perfect but just want it to blend in a bit.
You might try a colored wood oil product, like this stuff:
I have had good luck with blending out small nicks and scratches. Won't be perfect but easier than a complete refinish.
  • I appreciate the suggestion. There is still some gunk from the pads on the bottom of the socks still stuck to the surface. I would assume it would be wise to remove that before trying this cover up. Any recommendations for removing that? Would something like Goo Gone be good? – gboh Sep 4 '18 at 2:41
  • Goo Gone or any other solvent product may smear the finish, perhaps tragically. On the other hand, on lacquer based finishes I have in the past used a small amount of lacquer thinner to blend away scratches and nicks by smearing the finish. I don't recommend trying it though, at least not without testing on an inconspicuous area. Try warm soapy water to remove the rubber dabs. – Jimmy Fix-it Sep 5 '18 at 5:01
Looks like mahogany… I agree with previous commenter’ answer, but you might want to get a specific mahogany scratch fix like this: http://www.howardproducts.com/product/restor-a-finish/
