I am replacing an old fan/light combo that was operated by side by side light switches. I have replaced it with a light/fan combo that also has a remote. I can only get the light switch to operate either the fan or light. One side of the remote has a black and white wire which I have connected to the black and white from the ceiling. The other side of the remote has a black blue and white which are connected to the black blue and white from the fan.
There is also a red wire that is coming out of the ceiling, I tried connecting it to he two blues from the remote and Dan and then I tried connecting t to the black wires from the remote and fan. Either way the light switches will operate either the fan or light but not both. Any suggestions?
  • Can you add some images of your junction boxes? – Machavity Aug 31 '18 at 20:31
    Do you want to be able to use the remote still, and if so, do you still want dimming and/or fan speed control functions from it? Are you open to replacing the existing wall switches? – ThreePhaseEel Aug 31 '18 at 22:23
