I'm considering attaching a new towel rail to the drywall in my bathroom, with attachment points approximately marked by the yellow postit notes in this picture.
This is on the 21st floor of a condo building in Montreal (built in 2014). The building manager said the drywall is approximately 1" thick (a full inch! not a centimeter).
  1. Is this really possible? (I haven't been able to get confirmation from anyone else).
  2. If the drywall is really 1" thick, will the usual drywall anchors be effective? Usually the pictures I see of drywall anchors have them exceed the thickness of the drywall by around 1/2", and have expanders which end up significantly expanded after the screw is inserted. However, most anchors are at most 1" long, and in a 1" thick drywall, there probably won't be much room for the expanders to expand. Will this decrease the effectiveness of the anchors?
  3. Another issue is the nearby thermostat/light switches. How do I make sure to avoid any of their wiring when drilling in the drywall anchors? Is it important to avoid them? Part of this I suppose comes down to how the wires are arranged behind thew all. Will they for example come bundled in a metal tube? (In this case hitting the metal tube may cause the tube to flex undesirably?
  4. Is there anything else I need to watch for? How can I tell if there's plumbing behind the wall?
  5. If I gently drill a small hole, poke into the hole with a toothpick and check there's nothing within an inch behind the wall to worry about, is that a guarantee I'll be fine?
  • A toothpick will not reach far enough to probe through 1/2" drywall, much less 1" drywall; use a longer and heavier probe. You could use magnet stud finders to find the metal studs--you actually are finding the drywall screws. If you have metal studs, I would think you'd want to avoid them rather than try to use them. Aug 31, 2018 at 17:53
Figure out what is there first
As you noted, there are wires, and possibly plumbing (though less likely) in the wall. Drilling a pilot hole is a good way to verify the thickness of the drywall (1/2" is typical - but there are sometimes 2 layers = 1"). The other thing you might run into, which is a good thing to find is a stud. In a recent building, the studs may turn out to be metal rather than traditional wood. Either way, studs are great for mounting towel bars, and anything else. The one catch is that a pilot hole over a metal stud may not be immediately distinguishable from a pilot hole over a metal plate that is protecting wiring.
In a Stud
If either end of the towel bar lines up with a stud, then use long screws - typically around 1" longer than drywall + mounting hardware - to go directly into the stud. No anchors needed!
For wood studs, use cabinet screws. Do not use drywall screws - they are designed to attach the drywall to the studs and not for attaching over things on top of the drywall - they are handy in a pinch for all kinds of temporary and/or low-strength applications, but not for long-lasting heavy-duty applications.
For metal studs, drill larger holes and use toggle bolts. While you can use toggle bolts as anchors in drywall without studs, with metal studs you don't have to worry about the drywall crumbling under pressure - done right they will last forever even if people use the towel bar as a grab bar.
Into a Hollow Wall
Unfortunately, most of the time at least one end of the towel bar will end up over a hollow wall cavity. There are a variety of anchors used for this - most people swear by some and swear at others. There are plenty of plastic expanding anchors, as well as toggle bolts and other gadgets. Check the rating and get stronger than you think you need. A towel bar, unlike a mirror or many other things, will be used at least occasionally as a grab bar due to the nature of bathrooms - wet feet, slippery floors, etc.
All that being said, good quality anchors are fine for a regular towel bar if you can't get into the studs.
A real grab bar?
If you actually need a true grab bar - and there are plenty of towel bars designed to do double-duty as a grab bar - then you really want to get into studs on both ends or add extra backing (either cut into the wall, add wood, patch over and screw into it like studs; or a painted/stained wood piece placed over the drywall, screwed into studs and towel bar on top of that). But based on the picture, it looks like the towel bar will be next to the sink and not next to the tub/shower, so an "ordinary" installation should be sufficient.
  • Are drywall anchors which are good for 1/2" drywall also good for 1" drywall? I recently bought a set of snapskru drywall anchors, which have expanding tips, but being only 1" long, there won't be any room for the tips of the anchors to expand if drilled into a 1" thick drywall. Is this a problem, or does it make the anchors even more effective?
    – Will Chen
    Aug 31, 2018 at 15:26
  • Anchors are most effective if they are longer. But you first need to determine (with a pilot hole or two) whether the drywall is really 1/2" or 1". Aug 31, 2018 at 16:01
  • Can you describe what type of anchors I should use for a 1" drywall vs a 1/2" drywall?
    – Will Chen
    Aug 31, 2018 at 16:06
    Look for "double" - e.g., a quick Google search for drywall anchors double thick found this fasteners.stanleysupplyonline.com/viewitems/… Aug 31, 2018 at 16:09
    Note that the plastic anchors double thick found by manassenkatz only require a 5/16" hole. I think that these or equivalent would be sufficient. Aug 31, 2018 at 17:59
The "1 inch drywall" might be correct depending on how you asked the question: "How thick is the drywall in my bathroom next to the door?" vs "How think is the drywall in my condo?" could have different answers. If you are looking at a "COMMON WALL" meaning between two condo units, it's not unusual for (thoughtful) builders to use two layers of 1/2" drywall for sound deadening between adjacent units. But obviously because there is a door where you want to put this, and I doubt that door gives access to you bathroom for your next door neighbor, there would have been no valid reason for the builder to have doubled up on the drywall there.
For a standard towel rack to be used by a responsible adult look at the screws that come with the brackets and get the plastic drywall anchors which are sized for that size screw. I believe that they should work in this wall. I think the hole size for these would be 1/4" or at most 5/16". The instructions for the anchors should give the hole size for those anchors. The anchors will be a little more than 1" long and will probably grip the sides of a hole in 1" thick drywall sufficiently for this application.
But if you want a superior installation which would tolerate hard use, indefinitely, then go to longer anchors. You could investigate the Wingits towel racks. If these are mounted with Wingits drywall anchors they will require a 3/4" diameter hole. See Wingits site with installation instructions
