I was walking up the stairs and when I reached the top step my foot slid forward and wiped out. When I looked up, I saw that a panel had slightly moved, but when I tried to move the panel back into place it wouldn’t budge. How do I fix this?!? Please help!enter image description hereenter image description here
  • The picture does not seem to describe the problem well enough for us to understand. Could you please add to the problem description to clarify? What does the picture show and where is the "panel" that shifted, in the picture? – Jimmy Fix-it Aug 31 '18 at 6:05
    I see it now, I was confused too. A floor board has moved. What looks like a piece of paper laying on the floor at first glance is actually a hole. It’s odd, you must have had quite a fall. I wonder which part moved the long board, or the short that’s is toward the wall? (@JimmyFix-it look again with my added words) – Tyson Aug 31 '18 at 9:27
  • Hello, and welcome to Stack Exchange. What does the other end of this board look like? Does it butt up against a second board, or go all the way to the end of the flooring? (Another picture would be great.) – Daniel Griscom Aug 31 '18 at 12:40
  • It looks like you've created a second "Trevor Arteaga" account. You should get these two accounts merged. – Daniel Griscom Aug 31 '18 at 16:05
  • Did my second picture help with the perspective? @Tyson – Trevor Arteaga Aug 31 '18 at 16:33
