I purchased wooded undeveloped property and there is a box mounted on a pole with 200 amp service. The person before me tapped in to the box for his RV with 10-2 wire with the hot going directly to the lug coming off the main breakers. The neutral is also wired to a lug and the ground goes to a bus bar. There hot wire is not going to a 30 amp circuit breaker (for the RV). I believe I need to add a 30 amp breaker. Also I would like to add an outdoor outlet (110 v) from the box and would therefore need to add another 15 amp breaker. Is that correct?
I purchased a small bus bar from Home Depot. If I remove the Neutral lug, does this just screw in?
It looks as though if I flip the breaker bar off, everything below the breakers should not have current.
I appreciate the assistance and help from this more knowledgeable community.
