What could cause a motion sensor to blink at a steady frequency when it is turned on?
We've had an outdoor motions sensor flood light that hasn't worked, we presume because the bulbs died. After much delay and various electrical works on our house, we finally took the existing bulbs out, got replacements, and installed both of them. Testing it out now, we find the light flickering at a constant, relatively fast frequency! Before changing the bulbs it did not turn on at all. When switching it off, it turns off, and when switching it on it begins flickering almost every time we've tested it. The flickering is very steady and rapid, which makes me think it is not a loose wire anywhere but rather some more 'stable' or steady problem.
I've tested the different settings on the motion sensor and they didn't change or stop the flickering in any orderly way, though the flickering did in one case not start until it saw motion, and in another seemingly random case the flickering was slower and then got faster.
We've had electrical work done on the house, including on the circuit we think this light was on. We were never 100% sure which circuit the light was on because when testing circuits we presumed the bulbs were just dead and they're high up so we hadn't replaced them, but based on location of the light and other wiring we know of, we're pretty confident which it's on. So far there's no other signs of electrical issues in the house.
Here's a photo of the back label of the motion sensor light:
And a photo of the settings/options on the bottom of the motions sensor:
And the new bulbs we replaced the old ones with:
Here's a video of the lights being turned on and blinking: https://vimeo.com/user88849293/review/286817079/b741e8c936
How can we fix this? What would next troubleshooting steps be?
