I have a Kohler single-control faucet on my kitchen sink that I installed about ten years ago. Starting about a year ago, it would occasionally not turn on smoothly, but would spurt with a harsh thudding sound once or twice before flowing normally. It seemed as if something inside was moving to block the water flow momentarily with a water-hammer effect. This only happened upon turning it on, never while it was already on.
It slowly got more frequent and sometimes water flow would stop entirely after a spurt/thud until turning the handle off and back on again.
A few weeks ago, I finally replaced the valve cartridge with a genuine part (link) and also replaced o-rings in the faucet body.
This seemed to fix the problem. However, the faucet is already starting to thud and spurt while turning it on again. What can I do to permanently fix it?
During the faucet repair, I also discovered one of the shut-off valves under the sink was leaky. I think it had a very slight drip before, but started leaking significantly when I shut it off. Following advice I found online, I tightened the packing nut and it stopped dripping. Could this be related to the faucet problem?
Edit: To address the question from @Machavity, I don't see a visible part marking or recall specifically, but it looks like the "Forté" model with a sprayer as listed on the Kohler website (K-10416-BN).
It just crossed my mind that the sprayer has a diverter valve. The sprayer itself works OK. Could a failing valve cause this problem?
Update: After thinking of the sprayer the other day, I tested it. Most of the time it did work just fine, but a couple times it would shudder when releasing the spray button, and once the flow did not return to the faucet when I turned the sprayer off. I replaced the diverter valve today and it is working well at least for now. The old valve was noticeably worn, but didn't have any obvious functional problems.
Kohler Forté
    Do you have a model number for the faucet? – Machavity Aug 25 '18 at 23:45
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
