I have a small bathroom with exterior walls in an area of my home with a vaulted ceiling (and thus no attic access.) When I moved in, the exhaust fan was uselessly "exhausting" directly into a fiberglass batt.
I'm hesitant to cut a hole in my roof to exhaust the fan properly, but if I go a few more feet I think I can access the soffit area and place a vent there. What I'm not familiar with is whether or not I can expect some kind of obstruction between the roof joists over the exterior wall.
Proposed Diagram
This is a rough sketch of what I intend to do - however, before I go yanking the existing insulation out from between my rafters to make room for the flex duct, can anyone tell me if this makes sense? Should I be able to snake a flex duct between the rafters and into the void between the soffit and overhang?
  • Hello, and welcome to Stack Exchange. Good question: keep 'em coming! – Daniel Griscom Aug 24 '18 at 17:53
  • Makes sense to me, but I do not think you need the right angle vent showing on the underside of the soffit. supplyhouse.com/… – Jim Stewart Aug 24 '18 at 18:19
  • @JimStewart Alright, I'll look into what's available. I originally chose the right angle because it's the only "louvered" one I could find that would allow the door to close when mounted in a soffit; I think the "dryer-vent style" ones are all gravity-close on the louvers. Either way that's not a biggie. Thanks for the reply! =) – VanGoghComplex Aug 24 '18 at 18:24
  • At least some of the fan units have the gravity closure door on the fan unit itself. – Jim Stewart Aug 24 '18 at 18:48
    Mine has that door, and I hear it during stormy weather as air pressure changes open and close it. – DaveM Aug 26 '18 at 3:55
Welp, it worked just fine!
Welp, it worked out just fine! Still need to caulk it and paint it, but it installed easy and it's amazing the difference a properly vented bathroom makes.
  • I've done a similar thing with my bathroom vents, but I did find an outlet vent that didn't hang down like that. – DaveM Aug 26 '18 at 3:54
