I used a home mold test kit (leftover from my previous question) to see if I had mold in my basement (where I sleep). Turns out a little bit of mold is growing in the petri dish. The mold looks to be greenish in color, almost a green-white. It also looks a bit fuzzy. I looked around and cannot find any source of it, so I figured I would clean all of the wood beams, insulation, and walls as well as run a dehumidifier and air purifier (with HEPA filter) to get rid of and prevent the mold. The biggest issue is that there is one part of the ceiling that is drywalled, and a part that isnt (the main cable line as well as water lines needed to be accessible)
I was considering just spraying some vinegar behind the drywalled section because I cannot reach behind there to scrub, nor can I see all that well to target specific sections should I see mold. I figured the vinegar would kill the mold even without scrubbing, and the dehumidifier would prevent the spores (which apparently cannot "die"?) from spawning new colonies.
Is this an effective plan? Or will the vinegar add moisture to the drywall/wood studs and actually feed the mold? Is there a more effective way to treat the mold and prevent it in the room?
PS: the room as only a small basement window and cannot be opened, so air flow is poor, so I am trying to avoid bleach/ammonia. Plus I heard they cannot penetrate porous surfaces anyway
