I'm going to be replacing the breaker box in my condo and I'm looking more to the details now. I see that the main service entrance cable ground has some goo where is connected to the ground bar in the breaker box, see picture pls. Is this something normal I should get and apply when I install the new panel? or is it nothing to worry about? Thanks enter image description here
  • Great picture +1
    – Michael Karas
    Commented Aug 19, 2018 at 18:16
It looks to be anti-oxidant that's gotten...crusty
Normal practice when terminating aluminum wires (such as the feeder to your condo) is to use an anti-oxidant paste or compound when making the connection -- this is said to keep aluminum oxide from forming between the joint surfaces and causing a high-resistance (read: bad) connection.
What you're seeing is likely an excess of anti-oxidant compound from the original installation, that's simply accumulated crud over the years. You or your electrician will be cleaning it off and putting new stuff on as part of the installation process for the new panel.
