I am doing a backsplash project with 12x12 mosaic travertine tile on mesh
Some of the 2x2 tiles have holes and imperfections which I hope to fill with grout which is the same color as the tile
I am planning to seal the tiles before I adhere them to the walls.............
My question is if the tile is sealed with 511 impregnator sealer prior to adhering to the wall will the grout adhere to the holes?
Should I fill in the holes before I seal the tiles?
    If you seal the tiles prior to installing them, I’d be concerned that they may not adhere to the wall. Why not seal everything after installation? – Lee Sam Aug 18 '18 at 13:56
  • My advice s to install then wipe with sealer not saturating then fill holes and grout lines this helps keep grit from bonding to surface After dry seal it all well – Kris Sep 27 '20 at 16:59
Seal after the install. Some material does come pre-sealed but I have only seen it sealed by the professionals after installation
