I'd like to add an outlet to a 1st floor hall closet where I store tools. The water meter for the house is in this closet, but nothing else (e.g. no water heater, furnace, etc.). The closet is roughly 8'x 4'. The outlet will be used to charge batteries for drills, vacuums, etc. -- so very low amperage. I'd like to wire the outlet into a dedicated 20A circuit I have for a sump pump. I don't have a sump pump and don't anticipate getting one, so the outlet is going unused. The sump pump outlet is close to the closet, so tapping into it would be very convenient. I plan on making the new outlet 20A and running 12/2 cable to be consistent. Any concerns with this approach?
  • This could be done but in my area if used for a sump pump non GFCI it must be a dedicated circuit. If you put a GFCI outlet at the sump pump location then I would see no problem with using this supply for your needs.
    Aug 17, 2018 at 21:10
Sump pumps have usually been put in on dedicated circuits, possibly to get around the GFCI requirement, but you say you don't have a sump or expect to ever. Based on what I can find in the National Electric Code, I would say it is okay to use it, but you should check local ordinances. Your wiring plan is fine, properly sized wire for the circuit breaker and probably oversized for the charging equipment you expect. NEC 210.8(A)(4) includes crawl spaces in the GFCI requirement, but if your receptacle is going to be in a closet above grade (not in an unfinished portion of a basement) you wouldn't need GFCI there.
If you decide to also leave the sump receptacle in place, in case you need to plug in a light or something in the crawl space, it should be converted to GFCI, but to avoid confusion I wouldn't protect the closet one from there. In other words, use the terminals marked on the back of the GFCI "Line," and do not use the terminals marked "Load." That way if it trips it won't turn the closet receptacle off as well.
The only issue I would anticipate is that the sump pump outlet is probably not arc fault protected. Depending on your local code requirements, you are probably required to have arc fault protection on a circuit supplying receptacles in a closet.
  • Thanks. I forgot to add that the sump outlet is in a crawl space but not a GFCI. I recently had an electrician add an outlet down there for a tankless water heater and he did not use a GFCI, if that means anything.
    – Rick
    Aug 17, 2018 at 22:01
